Hi All. My father-in-law has a 91 F150 5.0 pickup and it started running real bad. Well, he asked if I could check it out and fix it. It's the old son-in-law test, I think! Anyhow I found this site and have been reading through it to get ideas on what the problem might be. I'm very impressed with the info I've found.
So far, I found that some criters have gnawed at the spark plug wires. So I changed the plugs and the wires. I discovered that the three wires leading to the TPS was also bare and actually touching each other. Would this pretty much toast the TPS?
We are happy you have chosen the best source for Fords!
Enjoy FTE and The State Chapters are located at the bottom of the main forum page. JOIN CLUB FTE -SUPPORT THE FORUMS!
See you on the boards. ….
