94.5 Psd Surging
Old May 28, 2006 | 08:23 AM
94.5PWRSTRK's Avatar
94.5PWRSTRK
94.5 Psd Surging
This a 94.5 psd F-350 with 250,000 miles on it. Has been running great with plenty of power, easy starting. Lately I have been getting a surge or power loss/gain which feels like a missing plug would feel on a gas burner. This is most evident after the engine has heated up well, say after a good hour of highway driving and is most noticible in the lower rpm band. It will idle all day without a miss and seems to do well on top end. This happens under acceleration and at speed. I have drained the fuel, tried fuel additives and changed filters several times with no change. This has been going on every work day for several months. Right now it has been at the dealers for a week and guess what? THEY CAN'T GET IT TO DO IT! Any ideas? Thanks.
Old May 28, 2006 | 11:53 AM
1997F-350's Avatar
1997F-350
sounds like an injector or 2 not firing.
cheapest way for you to diagnose. it to pull the vc's, start truck and observe oil spouts for oil from all injectors.
been there done that...
8 beans later and it runs like a bat out of
Old May 28, 2006 | 09:19 PM
94.5PWRSTRK
So each injector senses independently and there could possibly be some kind of blockage to one or more ? or would there be a bad sensor ? I am ignorant of whether the injector relies on the actual pressure directly or on a signal from some sort of sensor that monitors the pressure. Thanks for the input.
Old May 29, 2006 | 12:55 PM
plowhand's Avatar
plowhand
Playing in the Dirt
94.5PWRSTRK, check out this site, it explains how the injectors work. Maybe it will answer some of your questions.
http://www.intellidog.com/dieselmann/injector.htm
Old May 29, 2006 | 09:33 PM
94.5PWRSTRK
Great site plowhand, thanks.
