Fuel Leak
Old May 27, 2006 | 01:29 PM
FARM69's Avatar
FARM69
Fuel Leak
On my 97' stroker, I've finally found the fuel leak I've been smelling for about 2 months now. Its to the right of the fuel filter. However I do not know the name of this part (thinkin it might be the fuel pressure regulator). It appears to have treads on one end of the brass? piece and a wire ( i think its red) on the other end of it. I believe this part tells the comp how much fuel to give the engine. At idle it surges a little bit every now and then.
My second problem... After I turn the engine over and it idles for about 10 seconds, a squirting type sounds is heard and the engine pulls down a little bit. This dosen't happen after every startup, mainly when the engine is cold. It only does it for a few seconds then runs fine.
Sorry for the long post... I don't have a computer handy anymore.
Old May 27, 2006 | 06:39 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
That is the fuel pressure regulator.
I would imagne the sound you are hearing is the fuel system repressurizing. Probably hearing the air being pushed out of the leak at the regulator.
austinkb
1997 - 2003 F150
Aug 16, 2016 12:22 AM
TheKirbyMan
Apr 23, 2016 05:13 PM
leitmotif
16
Oct 16, 2015 04:43 PM
brooklyn
13
Jan 26, 2010 08:39 PM
JBronco
1978 - 1996 Big Bronco
Sep 27, 2006 06:04 PM
