Fuel Filter
Old May 26, 2006 | 08:28 PM
Dragon's Avatar
Dragon
Fuel Filter
How do you get the dang thing off/ I have removed the clips on both sides. Does the hose just pull off from here. I have given both a good tug, but it does not budge. Is there some other trick?
Old May 26, 2006 | 10:38 PM
FTE Herman's Avatar
FTE Herman
Usually, when you push the tool in to expand the spring, the fuel line just pulls out.
Old May 27, 2006 | 08:14 AM
holiday187's Avatar
holiday187
make sure you releave the fuel pressure athe fuel rail that will help make it come off easier.
Old May 27, 2006 | 01:55 PM
ga4kicks's Avatar
ga4kicks
Need special Tool
After the same frustration to get the FF off, I finally went and bought a tool to remove the FF from my local autoparts store. Came off in seconds with the tool.
