radius bushing.
Old May 26, 2006 | 02:24 PM
1964 4x4's Avatar
1964 4x4
radius bushing.
how does one go about replaceing it while only doing one side?
Old May 26, 2006 | 02:27 PM
ford390gashog's Avatar
ford390gashog
well the most common way is to remove the i beam and unbolt the spring and push it forward enough to install the new bushings. you also want to do both sides not just one! most come as sets of 2 so just do both sides.
Old May 26, 2006 | 07:30 PM
I_Thnk_Ford's Avatar
I_Thnk_Ford
In addition, once up get the radius arms out; grind, cut or chisel the rivots out and replace the rivots with grade 8 bolts.
The next time you have to replace the bushings, you can unbolt them instead.
Robert P.
