Sponsored by: Auxito
Sliding rear window swap
Old May 26, 2006 | 02:17 PM
Glen Murphy's Avatar
Glen Murphy
Thumbs up Sliding rear window swap
I have a 97 F150 super cab 4x4 with a broken rear window. The folks at autoglass told me it was a 1 piece bolt in unit. I'm wondering how difficult it would be to take it out myself and get a replacement from junkyard. Any advice would be greatly appreciated.
Old May 26, 2006 | 04:58 PM
SPELLY F150's Avatar
SPELLY F150
To replace the rear windows is not that hard. You have to remove some of the plastic trim around the window and remove the nuts holding the window in. Then push out the old window. Then you have to clean off the old sealant. Install new sealant on the used window and reverse the process you used to take it out. NOTE: A new window installed will run about $275-$350 from an auto glass company.
Old May 30, 2006 | 07:55 AM
Glen Murphy
Thanks for the info.I might be better off to just pay someone to do it .
