View Poll Results: Should I replace the compressor?
Yes
0%
No
100.00%
Voters: 2. You may not vote on this poll
Replaceing my compressor?
Old May 26, 2006 | 12:27 PM
CdnSoldier's Avatar
CdnSoldier
Question Replaceing my compressor?
Any hard core AC SMEs out there? The question I have is about replacing my compressor. I have a 94 Aerostar rear air and replacing the Accum, Condensor, both under body lines and the manifold and Raf line inthe rear, etc. It will be new 1000$ worth, except for 2 lines, and the 2 evaps.
I was told I should replace the compressor, because it has not ran for about 3 yrs, by one shop and no need by another. My AC book, does not give details or hints. At 500+$ for one I'm questioning the need. It
Any points yes or no?
Old May 26, 2006 | 12:59 PM
rusty70f100's Avatar
rusty70f100
I guess I'd be asking how many miles are on the vehicle, and are there any signs of leakage?
Normally Ford compressors of that era were quite reliable, from what I hear. Off the top of my head I'd say no need to replace it if there's no signs of leakage.
Old May 26, 2006 | 03:43 PM
CdnSoldier's Avatar
CdnSoldier
My van only had 100,000ks on when the condenser blew a hole in it from a rock. It only has 118,000ks now.I never go around to fixing it. Since I'm fixing it, I'm replacing what requires it. The Manifold line and rear filter line I'm replacing to play it save. Now I have the cash and am moving so, I would like to have the air on the Hwy. It does get hot in Canada.
It just bugs me the I'm getting a 50/50 stance on compressor replacment. I hope someone has a yes or no answer.
Thanks Dave
Old Jun 2, 2006 | 11:03 PM
rusty70f100
Well, if the system has essentially been open for that long, I'd look at replacing more than the condenser and the line. I'd definately replace the accumulator / drier too. Was this originally an R134a system? If not, it would probably be best to take everything apart and put in new o-rings. Unless your laws are different in Canada, this need not be an expensive deal if you're willing to get your hands dirty. Parts stores should carry all the parts you need, including the oil. Then, simply take it to a shop, or the parts store, and have them pull a vacuum on the system. Charge as necessary, and away you go!
Two votes for no and none for yes on the compressor replacement. With only that many kilometers, I'd say that the compressor is probably still in real good shape.
I just got done with something similar. Go review my threads in this forum.
Old Jun 3, 2006 | 06:32 AM
CdnSoldier's Avatar
CdnSoldier
Here in Canada you can replace anything yourself. But you cannot purchase R12 or R134 unless you are a licenced shop. I am replacing the other parts also. It was just the compressor. As I stated some shops say yes, some say no.
Old Jun 3, 2006 | 07:40 AM
tjc transport's Avatar
tjc transport
i ain't rite
with the comparison in price between the compressor and a charge, if it was mine, i would not replace the compressor if it was working fine before the rock took the condensor out. i would charge the system, and go with that.
Old Jun 3, 2006 | 10:05 PM
rusty70f100
Could you take a trip south, and have it be magically charged when you return... if you know what I mean?
