Rebuilding oil pump
Old May 25, 2006 | 10:54 PM
David-ID1's Avatar
David-ID1
Red face Rebuilding oil pump
Can anyone help me find a gasket for the late flathead 8BA oil pump? I need the gasket for the gear plate.
David
Old May 25, 2006 | 11:11 PM
ALBUQ F-1's Avatar
ALBUQ F-1
If it's in the FelPro complete engine gasket set, I have one. I'll check and get back to you. Just curious, why not just buy a new pump? They're cheap and "pretty important"! I always wondered what good it would do to replace the gears but not the casing.
Old May 26, 2006 | 11:43 AM
David-ID1's Avatar
David-ID1
Smile
I think the pumps are fine, I took the top off to check the gears. I have two of them. This motor is becoming a money pit. I am rebuilding the starter also. I have a lot more time than I do money.
Thanks,
David
Old May 26, 2006 | 02:28 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I'm not seeing that gasket in my set; I used the one that goes at the base of the pump on mine. I'd bet the one on the cover is special (thin), as it sets the clearance on the end of the gears. I wonder if you could use LocTite flange sealant in place of the gasket? As long as the gears spun freely using that, you should be OK.
http://www.loctite.com/int_henkel/lo...id=19&layout=3
PS -- as far as the truck being a money pit, think of it as "entertainment", it helps!
Old May 31, 2006 | 12:11 PM
53fatfndr's Avatar
53fatfndr
David
If you are still looking for a gasket and can't find one, go to NAPA and buy a sheet of gasket maker material. Tell them what it is for so you get the correct material. All you have to do is trace your part and cut it out. It would be easier to find the precut gasket, however.
