HELP PLEASE! '85 F-350 Electronics Issue
The problem started when I appearsed to have some "bad" grounds [See my posts in the https://www.ford-trucks.com/forums/s...&goto=newpost].
I proceeded to replace the smaller (2) "melted" grounds on the right side battery. The large ground seemed ok that was going to the engine on the right side exhaust manifold. After I replaced those, cleaned up the battery terminals and then tightened the terminals, the truck started right up. I was originally having trouble starting the truck up after it was "warm" [per prev thread". I let the truck run for approx 5 mintues in my driveway and next thing it just stalls. I go over an try to re-start it, and then my factory clock, radio go out and it does not start. I also noticed I did not have the rear lamps, trun signals, emerg flashers, cig lighter, but the dome light was on, the lights worked and the door buzzer worked (apparently everything that does not require the use of "swicted power"). I get nothing now when I turn the key.
What could be the problem? Ignition, Starter Relay, Voltage reg on the right side inner fender wall, both, ignition swicth? etc.
I really need your help on this one.
Coneynew
