Springs
Old Mar 4, 2002 | 10:39 PM
AaronW's Avatar
AaronW
Springs
I want to put blocks on my rear end of my 69 F250. It has helper leafs on it already, 4 leafs separators then 4 more smaller leafs. So it already has tall U-bolts. Is it safe to run longer U-bolts, if so, are they expensive to have made?
Thanks
Aaron
Old Mar 5, 2002 | 01:34 PM
sb2371's Avatar
sb2371
Springs
Aaron,
my 71 has 7 leafs then a 4 leaf helper.... pretty stout rear end (for a 1/2 ton). I would try Autozone or some other parts store for longer bolts.... if not you could probably get a machine shop to fabricate a couple..... if you have a tap and die set and a torch, you could more than likely do it yourself..... but I would get a shope to make them as tempered steel can do strang stuff when you start heating it.......
Old Mar 6, 2002 | 08:28 PM
proeliator's Avatar
proeliator
Springs
Your F-250 should already have factory blocks on it. I wouldn't advise stacking rear blocks unless you are a fan of axle wrap.
Old Mar 6, 2002 | 09:21 PM
Mil1ion's Avatar
Mil1ion
Springs
