Radiator issues
Old May 25, 2006 | 08:19 AM
wolftan's Avatar
wolftan
Radiator issues
I have a small pin hole leak somewhere in the radiator on my 99 350 with 170K miles....but not much leaks so i just fill it out every so often. Yesterday i filled it up, drove for about 20 miles and was in the engine looking at something else and notice all the coolant was almost gone, but didn't see any major leak. Filled it up again and haven't seen any changes since then.....could this be a thermostat going bad and it opened up to let most of it in? I did check the oil just to make sure it didn't go there. I do have the 203 thermostat on the way, but is there something else i need to check? Thanks
Old May 25, 2006 | 05:51 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Almost gone from the degas bottle, or the whole system was empty? How much did you have to add to top it off?
If it's not in the oil and you are not blowing billowy clouds of steam, it's probably just a leak.
Old May 26, 2006 | 06:58 AM
wolftan's Avatar
wolftan
Almost gone from the reservoir....i needed about a gallon of antifreeze to fill it back out. I am wondering if my thermostat is bad.
Old May 27, 2006 | 12:00 AM
cookie88's Avatar
cookie88
FTE Emeritus
Truck would overheat with a bad thermostat.
Maybe rent a pressure tester from teh parts place and see if you can pinpoint the leak....if there is one.
Old May 27, 2006 | 06:44 AM
Kwikkordead's Avatar
Kwikkordead
With that much coolant flowing out, it's a good chance you'll be able to see a trail. Have you rolled under and looked up?
Old May 29, 2006 | 07:22 PM
Bossman7121's Avatar
Bossman7121
I just came across the same problem, almost exact miles. At the top of the upper radiator hose where it meets the engine, it seems to be leaking (Seems b/c all coolant in degas is gone and on floor, and truck is still too hot to refill). Is this where the thermostat is? And / or how hard is it to replace water pump?
Bossman
Old May 30, 2006 | 07:48 AM
wolftan's Avatar
wolftan
I looked under and only could find a small drip....ran some copper stop leak through this weekend and still have the drip. Oh well, at least i was able to flush out the system.
Old May 31, 2006 | 07:48 AM
Kwikkordead
Stop leak is your truck's worst enemy!!!
It will clog an otherwise good radiator, heater core, the abrasive particles will eat your waterpump seal. Seen it at work too many times.
Old May 31, 2006 | 07:59 AM
wolftan's Avatar
wolftan
guess i should have asked first....well i did flush the system quite a few times after i ran that stuff, so hopefully didn't mess anything up.....how else can i stop the leak?
Old May 31, 2006 | 08:04 AM
Kwikkordead
The first order of business is to find out just exactly what is leaking. It could be as simple as the o-ring on the bottom radiator hose flange.
tuxedobuttonquail
53
Jan 9, 2017 08:04 PM
deezdrama
Aug 21, 2016 02:33 PM
Cole Neese
15
Jan 3, 2014 04:33 PM
sfitzgerald351
1978 - 1996 Big Bronco
64
Jan 15, 2005 04:27 PM
ecsmith0624
Apr 30, 2004 10:09 PM
