Transmission problems 96 F150
Old May 25, 2006 | 08:15 AM
FlyTSI's Avatar
FlyTSI
I have a 96 4.9 ltr E4OD and the strangest thing happed to the tranny. I lent out my truck to a friend (big mistake) and he called me saying it had no foward gears.
When you put the truck in reverse it goes into reverse just fine. When you put it in neutral its fine. Nothing happens in drive and 2nd gear acts like it going to do something but the truck wont budge. The wierdest is when you put it in low it goes into reverse.
Any ideas?
Also im having alot of trouble locating a good used tranny and was wondering how hard if possible would it be to convert to a stick.
Thanks a million.
Old May 25, 2006 | 10:39 AM
bohiaa's Avatar
bohiaa
I'm sure you have checked the fluid. fluid levels are importaint on these trannies.
waht about the MLP have you checked that...
the ole saying is that If you have a Ford replace the MLP
Old May 25, 2006 | 10:51 AM
andym's Avatar
andym
Sounds like the MLPS to me as well.
Old May 25, 2006 | 05:51 PM
FlyTSI's Avatar
FlyTSI
Thanks for the replys. It was low on fluid but is full now. When it messed up they said it was puring fluid out, but when I added it and let it run for awhile it didnt seem to be leaking.
I have no idea what a MLP is? What does it do?
Thanks again.
Old May 25, 2006 | 05:53 PM
andym's Avatar
andym
It's the manual lever position sensor. It tells the electronic tranny what gear it should be in.
Old May 25, 2006 | 05:56 PM
FlyTSI's Avatar
FlyTSI
Can that cuase the truck to act like its stuck in 2 gears or something when I put it in 2nd?
Thanks again, it would make my day if it where something like that
Old May 26, 2006 | 10:07 PM
bohiaa's Avatar
bohiaa
Its a dealer only part... I just replaced mine on a 93 F150
I think it was like 115 or 120.00
pull codes First it will give you a code forget the number
f3fidy
15
Jun 14, 2020 05:50 AM
02GrayPowerStroke
1997 - 2003 F150
Dec 14, 2016 05:56 PM
benjisps1195
13
Sep 14, 2016 06:17 PM
Fordsmb
Dec 10, 2015 11:17 AM
chadcam84
Oct 15, 2015 11:15 AM
