Sponsored by: Real Truck
"clink" from front end
Old May 24, 2006 | 09:12 PM
liftmy250's Avatar
liftmy250
when i hit a bump or pothole or something of the sort i hear a loud "clink clink" noise coming from the front left wheel... i know motors pretty well but not suspension or drivetrains yet....what could this be? it's an 05 f250 v8 with 11k miles. thanks
Old May 24, 2006 | 09:23 PM
Kep4's Avatar
Kep4
Jäger
Is your truck 2WD or 4WD?
Could be a loose shock mount, bad sway bar bushing, or if it's 4WD then check where the stub shaft/U-joint are at the back of the wheel/hub assembly. There's a metal ring that's pressed in that can come loose.
Old May 25, 2006 | 07:22 PM
liftmy250's Avatar
liftmy250
it's 4WD, i'm not sure why they even make 2WD trucks :P thanks i'll check those out tomorrow. i looked around earlier but didn't see anything that looked peculiar....although there are a lot of damn bars running every which way down there!
Old May 25, 2006 | 10:35 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
It could also be something more serious, so check if the axle stubs rotate with the hubs unlocked. If they are "gritty" or just plain stuck, the inner spindle bearing (little needle bearnig the axle rides in) is probably shot.
Old May 25, 2006 | 11:13 PM
FtwoFityboy06's Avatar
FtwoFityboy06
i have the same noise ..... 06 f250 4x4 with 3k on it ... did it since day one ... no clue what it is ...
Old May 26, 2006 | 05:30 AM
liftmy250's Avatar
liftmy250
if it's something major then hopefully it's covered under warrenty...i don't have any suspension modifications so hopefully it won't be an issue
Old May 26, 2006 | 04:21 PM
trvlerzz's Avatar
trvlerzz
My 1st post
I had a noise on my F-150 years ago and tried bouncing on the bumber and everything but couldnt reproduce to clink. Then I took off the shocks and one of them had about 1/2" of slop causing a clink on the rebound, a defective shock.
