58 suspension questions
Old May 24, 2006 | 08:17 PM
prostreetrig's Avatar
prostreetrig
I have a 58 f250 and would like to get rid of the 8 lug setup, atleast on the front anyway, what will fit directly and what won't. Also, I am going for an old gasser look and I want the front end up a little higher. How do I do this? Could I use a stiffer spring off an f350? Any help would be appreciated.
Old May 24, 2006 | 10:12 PM
Col Flashman's Avatar
Col Flashman
You'll have to replace the front & rear Spindles/Axels hubs of the 8 lug pattern w/ the 5 lug pattern from an F-100, as if you don't replace Both Front & Rear, you'll Have to Carry 2 Different Spare Tires, an 8 & a 5 Lug pattern in case of a Flat on either of the afore mentioned.
A "New" set of F-350 Front Leaf Springs will achieve the desired Lift effect.
