underdash a/c water leak
Old May 24, 2006 | 06:22 PM
4by4ce's Avatar
4by4ce
I just noticed that the passenger side carpet area is soaking wet, probably from a plugged a/c drain. I have looked all underneath and in the engine compartment and do not see a drain or where it might be getting in. Has anyone else had this problem or know where the drain is?
Lamar
2004 4x4 Screw 5.4 FX4
Old May 24, 2006 | 09:30 PM
xtrm1stang's Avatar
xtrm1stang
check you rear window and 3rd brake light, water will leak in there and run down teh pass side under the carpet in the wiring channel and then settle in the passanger floor board, I've seen it before, and it can cause corrosion problems if not fixed.
