Aux Power Option
http://i41.photobucket.com/albums/e2...port/winch.jpg
and no, it is not hooked up to the crown vic, it just happens to look that way.
I'd put the battery in a box and anchor it down in there. Then I'd run heavy gauge wire to the winch. I'd put a service disconnect on the positive side. As to battery type, apparently most the folks are using regular automotive batteries. That seems to be enough to do the trick.
I think you could still use the battery charge circuit to charge up the battery while you're going down the road. I don't think it's a good idea to try and have that circuit on while you're running the winch, however. I'm concerned it might overload the circuit. When the winch is not drawing current, though, I doubt that whatever battery you put on there will be able to suck up 20 amps on charge unless it's very dead. That's just a shot from the hip, though. Ford designs that circuit for batteries in campers, I imagine...
Best of luck with your project.
You can probably find out how much amperage the winch draws in the specifications. They might just give you a minimum wire gauge (AWG) spec right off the bat in the installation section. I'd go at least one size up from the minimum.
I'd be inclined to think that you're going to be somewhere between 6 AWG and 2 AWG for that unit. That's about the same as what a starter motor is.
As stated before. Pin 4 charge circuit, and pin 7 normally connects to reverse lights.
the battery is currently held in place with a ratchet strap, because i have not extended the tongue to mount the gang box on yet. once that is done, the battery is going into a boat battery holder, then into the gang box, with a solar cell on the lid to keep it topped off.
battery with a minimum rating of 650
cold cranking amps is recommended
to obtain peak performance from your
winchA fully charged conventional automotive
winch
Here's a CCA chart from Interstate Batteries to help with specification:
http://www.ibsa.com/www_2001/content...oduct_auto.asp
ehow states "Install a circuit breaker between the battery and the winch. It is important to fit the correct circuit breaker size so that the winch is not subjected to either premature cut-out from too little power, or the truck is not damaged by too great a draw. The rating of the breaker should not be greater than the amperage rating of the wire. Industry standard for most types of winches is 30 amp on 10-gauge run of wire of less than 20 feet."
The heavy current draw of the winch over a long cable run (from truck battery to trailer), resulting voltage drop yeals a much lower operating voltage at the winch, potentially resulting in winch over heating from low speed operation and heavy loads.
Read more: How to Wire a Trailer Winch | eHow.com How to Wire a Trailer Winch | eHow.com
Hope this isn't too technical, also a down side with a battery on the trailer is keeping it charged up. Some pros tell me that you will most likely need to use a seperate charger between trailer usage / trips, unless trip run time is in the range of 4 - 6 hrs driving / pulling.
