4th Guage
Old May 24, 2006 | 05:16 PM
DesertDiesel's Avatar
DesertDiesel
4th Guage
If you could add a 4th guage to you set up, what would it be? The 3 existing being 1) Tranny temp
2) Boost
3) EGT
Old May 24, 2006 | 06:32 PM
02PSD4ME's Avatar
02PSD4ME
I already have 4, I have an Edge Juice with Attuide Platnum. EGT, Tranny Temp, Engine Temp and % load, or Gear, or % tranny slip, you get the Idea
Old May 24, 2006 | 08:16 PM
DesertDiesel
Cool-unfortunatley I have a 3 guage pod and will add one more on the steering column.
Old May 24, 2006 | 09:23 PM
NavyPowerstroker's Avatar
NavyPowerstroker
I would add engine temp to that fourth spot.
Old May 24, 2006 | 09:49 PM
DesertDiesel
Where is there a tap in the cooling system to add that? It is what I was thinking about doing but wasn't sure if I shoud do coolant or oil.
Old May 24, 2006 | 09:51 PM
NavyPowerstroker
I have coolant and oil but it is in my Banks PDA. I would do coolant but they are normally within 10 or so degrees of each other. I will have to research where to hook into for that.
Old May 24, 2006 | 10:28 PM
Maxium4x4's Avatar
Maxium4x4
Check my gallery.... Pre/Post turbo EGT gauges
Old May 24, 2006 | 10:38 PM
DesertDiesel
Hey Max...
How big of a difference do you see in between the two?
Old May 24, 2006 | 11:51 PM
Customz's Avatar
Customz
I have boost, volts, tranny, EGT and oil temp
Old May 25, 2006 | 01:17 PM
Maxium4x4's Avatar
Maxium4x4
Hey Max...
200 at idle or slower speeds 400 in higher RPM's I have mine mounted (within 4") to the turbo in the down pipe.
