Turning off OD when towing
Old May 31, 2006 | 09:56 AM
aklim's Avatar
aklim
Originally Posted by Clubwagon
There is some truth to that. On level ground, aerodynamic drag is a bigger concern than weight. The answer comes down to the same thing; load and gearing. If you can pull OD comfortably, then tow in OD.
My van doesn't have a big motor (its just a 5 liter) but I use it to tow my racecar (on an open trailer) all over the US. I have 200,000+ miles towing it since '97. When climbing mountains I cancel OD at the bottom and use the power from the additional rpm to climb.
I once had to tow an enclosed car hauler (a 22 ft Pace) when a friend had the transmission (in his Chevy truck) take a dump 250 miles from home. My van could handle the weight but the aero drag meant I had to tow in 3rd gear. It wouldn't pull OD on level ground. 3rd gear worked fine but because of the shorter gear, I had to drop my speed back rather than run the motor at an rpm that was higher than I was comfortable with. I knocked my cruise speed back about 10 mph and it did just fine.
So yes, aero drag is an issue. I have seen some travel trailers that are very tall, like towing a barn, I know the drag is enormous. But if the motor will pull it the transmission should be OK. Now there are limits. If you do a bunch of power adders and don't upgrade the transmission too, then you can overpower it.
Just trying to learn here but why then was my tranny temp about 80 above ambient when towing my toy hauler? It should have heated itself more.
Anyways, BTS said that with my tranny, I can tow in OD without a second thought unless the tranny is hunting. Of course, that is a built 4R100 not a stock version.
Old Jun 7, 2006 | 01:40 AM
Chance_Thomas's Avatar
Chance_Thomas
I tow my 14,000lbs 5th wheel in OD unless a steep hill or going down a steep hill but not too many of them in Texas
Old Jun 7, 2006 | 09:08 AM
aklim's Avatar
aklim
Talked to Brian at BTS and he said it should be able to tow in OD unless you get some huge grade. However he said I could leave his tranny in OD and forget about it. I can tell you that his tranny is all I could want in a tranny, bar none. Well, if it was free it would be better.
