Flywheel Replacement 101...
Old May 24, 2006 | 10:21 PM
Robbgt's Avatar
Robbgt
Thanks Mitch, i'll call NAPA in the AM and see what they want for a flywheel..... good point, just start at the bottom and work my way up, I just need to get under there and get going!
-Robb
Old May 24, 2006 | 10:44 PM
79f-250custom's Avatar
79f-250custom
The only thing that is gunna mess you up is if you rush. just take your time. look at everything and remember where they go and what order they went on. just take your time,it will save you so much time in the long run if you just take it slow.
Mitch
Old May 25, 2006 | 08:24 AM
plowhand's Avatar
plowhand
Playing in the Dirt
Robbgt, go to autozone.com, under "Current Vehicle" put in your truck info., click on "Reapair Info", click on "Vehicle Repair Guide", click on "Drivetrain",click on "Automatic Transmission", click on "Transmission Assembly", scroll down to your transmission. Not diesel specific, but it is the same transmission, and will guide you in the removal and installation. Good Luck.
Old May 25, 2006 | 10:08 AM
Robbgt's Avatar
Robbgt
Awesome! thanks!
Old May 25, 2006 | 06:06 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Click on the "got manual" link in 1997F-350's sig. You can read through the Ford procedures.
