Help....wont Start...just Died!!!
Old May 23, 2006 | 07:57 PM
DUALLYNOTED's Avatar
DUALLYNOTED
Exclamation Help....wont Start...just Died!!!
I was running fine all day...Stopped at a buddies house and when I left..Truck would not start...It would initially fire for a second and then die..would not stay running for more than a second...Im thinking fuel pump or fuel filter problem...Cant check now...will have to wait till AM. noticed 1 time today when driving a slight hesitation but it went away...it was a split second thing at about 50 MPH..Im pretty sure it has some bearing on the problem...Help..Any suggestions are appreciated
Old May 23, 2006 | 08:26 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Do you have a spare cam sensor you can plug in it?
Old May 23, 2006 | 08:35 PM
DUALLYNOTED
No I dont...Unfortunately Im not that familiar with the diesel engine...Had it 2 yrs and no problems...Until this...Can I buy 1 or is it expensive and not worth trying?
Old May 23, 2006 | 08:36 PM
Fraalan's Avatar
Fraalan
Blue CPS, 80-100$ easy pleasy japanese
Old May 23, 2006 | 08:47 PM
ryaneverk2's Avatar
ryaneverk2
You can look up CPS on ebay, or get one from Ford or International (where they're called CMP). I'd get the black one. Around $60 on Ebay, $100 or so from International.
Check the thread at the top of this section, called Common Mods, for links to info on the CPS such as changing it, etc.
Old May 23, 2006 | 08:51 PM
cookie88's Avatar
cookie88
FTE Emeritus
It is worth trying. A faulty camshaft position sensor is the cause of the unexplained "died, won't start" problem the vast majority of the time. You can get one for right around $100 if you have an International dealer close by....nearly double that at the Ford dealer.
Old May 23, 2006 | 08:54 PM
cruise409's Avatar
cruise409
You're absolutely right with studder at 50 MPH, and with what you've described so far, I think Cookie and Fraalan are right CPS (Cam Position Sensor)
It's about a 10 - 20 Min (or 2 beer) fix, with a 10mm bolt.
Here is just one of our sponsors that has a replacement:
Garrett Shields
Pure Diesel Power
FTE Sponsor
715-498-0707 Call anytime!
www.puredieselpower.com
These might take a few days to get or ask if they will overnight - if you are really in a pinch
Here's the link to the Blue CPS ($105).
https://www.ford-trucks.com/lc/lc.php?action=do&link=htt...oducts_id%3D126
Here's the stock ($88):
https://www.ford-trucks.com/lc/lc.ph...ucts _id%3D110
Or...See if you can find and International dealer in your area. Tell them it's for a T444E in a 4700
Here's a article from our tech site on how to install:
https://www.ford-trucks.com/article/...ke_Diesel.html
Another install from Pure Diesel Power (w/pics):
http://www.puredieselpower.com/Tech/CPS.pdf
Let us know if/when you change it and how is goes after.
Old May 23, 2006 | 08:56 PM
cruise409's Avatar
cruise409
Dang it...Cookie and Ryan are just "Johnny on the spot"............I'm just take too long to post.
Old May 23, 2006 | 09:01 PM
cookie88's Avatar
cookie88
FTE Emeritus
The up side is it was a very good post.
Old May 23, 2006 | 09:32 PM
DUALLYNOTED
I will try it and let you know how it goes...Thanks all!!!....I then have to locate it on Engine...It shows it in the book..just a matter of finding it.
Old May 23, 2006 | 09:50 PM
cookie88's Avatar
cookie88
FTE Emeritus
Old May 23, 2006 | 09:56 PM
DUALLYNOTED
Just bought 2 on ebay for 124.00 with 1 day shipping...even if its not the problem I guess they are good to have
Old May 24, 2006 | 08:45 AM
DUALLYNOTED
OK Heres the sysmptoms so Far....I went to get truck and it started right up this morning.....Drove about a half mile home...put in driveway and tried to restart it....NO DICE..same thing like yesterday...Does it still sound like the CPS????
Old May 24, 2006 | 08:55 AM
twags6's Avatar
twags6
Yes. Thats the funny thing about the CPS, it can be working fine one minute, flat out die for the next few days or so and magically work again. Have you replaced the CPS yet, or are you still waiting for them to arrive?
Old May 24, 2006 | 09:34 AM
DUALLYNOTED
still waiting for them..got a good deal so we will see...I will post when its replaced
