Check Engine Light on a Ford '98 Explorer?
Old May 23, 2006 | 07:09 PM
DrewFord's Avatar
DrewFord
Cool Check Engine Light on a Ford '98 Explorer?
Hi folks!
My Explorer just failed a state inspection because of a new law stating that the check engine light has to be off. The tech who checked out my Explorer said I had a bad Catalytic converter. Long story short, I dropped a lot of money and the check engine light is still on, despite driving around for 100+ miles, thinking the light would turn itself off.
How do I turn this thing off, or reset it? I have a retry at the inspection in a few days, so any and all information would be helpful!
DrewFord
Old May 23, 2006 | 07:47 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have on FTE. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
Old May 23, 2006 | 08:13 PM
Baumer's Avatar
Baumer
Check some of the sensors. such as the EGR sensor or o2 sensor.
Old May 24, 2006 | 08:32 AM
marragtop's Avatar
marragtop
The light may not go out just because the problem has been fixed. You can unhook the battery for 5 minutes which will reset the computer and the light. If it comes back on, you still have a problem. Also, in some states when they check emissions, if they can tell that the light has been reset recently (varies by state), they may not pass it. When you take it back, make sure you take your receipts and explain that you had repairs done and that the computer was reset as part of the repair process.
Old May 24, 2006 | 01:36 PM
87 XLT's Avatar
87 XLT
Some auto parts store like Autozone will pull the trouble codes for free.
Get the codes and post them here.
BTW, theres an 8 year 80K federal emmisions warranty on the cat convertor.
Edit So if one of the codes is a P-0420/cat convertor efficiency below threshold or some such & if you are under 80K miles, check with a Ford dealer.
Explorer180
Mar 15, 2011 10:32 PM
mwood1973
Jan 12, 2011 06:07 PM
billkean
17
Oct 15, 2009 11:32 AM
Ed
Mar 18, 2009 06:52 AM
