71 C6 modulator
Old May 23, 2006 | 04:25 AM
Bookman's Avatar
Bookman
71 C6 modulator
I thought the modulator was leaking so I thought i'd switch it out. When I got it from NAPA the guy says "you need to adjust this screw to the place". There is this adjuster at one end of the modulator but I have no reference point to go by. If I take off the old one is there a full tight or full loose position where it will screw to? Is there a number of screws in as the standard spot? What do I need to know to get it right?
Old May 23, 2006 | 06:14 AM
stuart1's Avatar
stuart1
Install it and take a quick spin.
If the shifts are too low and soft turn the screw in a couple of turns.
Contrary to popular belief it ain't rocket science.
Old May 23, 2006 | 05:28 PM
rclarke's Avatar
rclarke
A good starting point is with the screw flush with the end of the nipple.
Old May 23, 2006 | 06:19 PM
stuart1's Avatar
stuart1
Wrong rclarke.
The screw is not even close to the diaphragm at that point.
