Modular V10 (6.8l)
Ok I have a problem
Old May 22, 2006 | 11:23 PM
2000 excursion's Avatar
2000 excursion
Ok I have a problem
I have a 2000 excursion with the v-10. Every time I go outside to let it warm up in the mourning it wants to stall but then will pick and idle fine. It does it in the mourning and when it has been sitting at work for 16 hours.
Old May 22, 2006 | 11:25 PM
V10man's Avatar
V10man
I'd check your IAC valve. Will it keep runing if you give it a little gas?
Old May 23, 2006 | 06:48 AM
kenneBF250V10's Avatar
kenneBF250V10
Yep, definitely sounds like the IAC, only a 15 minute job to replace.
