Sponsored by: Kumho
removing rear blocks?
Old May 22, 2006 | 10:16 AM
omni's Avatar
omni
I would like to remove the rear block under the leaf spring on my 87 f-150 4x4, so the back will drop, and level out the truck. Is there any repercussion to doing this? I noticed all the 2wd trucks don't have a rear block. my truck never leaves the pavement, so I'm not worried about clearance. thanks Randy
Old May 22, 2006 | 11:33 PM
aurgathor's Avatar
aurgathor
Is that a straight (parallel) or wedge shaped block?
Old May 22, 2006 | 11:40 PM
omni's Avatar
omni
Thanks for the reply its a 2" straight block with that arm on it for the bottoming out rubber that hangs on the frame. do you think I can remove it without causing any problems?
Old May 23, 2006 | 09:51 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
you will be fine, likely you will need shorter ubolts
Old May 23, 2006 | 09:08 PM
omni's Avatar
omni
anything I need to know about tighting the U bolts, like torqueing them or just tighten them down really good? thanks Randy
Old May 23, 2006 | 09:49 PM
KubotaOrange76
im not sur eon the exaqct spec for your truck, but torque to around 85 ft lbs
make sure to recheck the Tq a few times within 500 miles after the install
Old May 23, 2006 | 11:34 PM
omni's Avatar
omni
got it! thanks.
Old May 24, 2006 | 06:34 PM
omni's Avatar
omni
Oh by the way would it be a bad idea to reuse the old U bolts?, it looks like theres enough thread on them to to handle the 2" drop
Old May 25, 2006 | 09:37 AM
KubotaOrange76
its not good but people doit all the time....they stretch when your torque them and its been said its bad to reuse them becaus eof that. you can get a set made at your local spring shop for cheap
Old May 26, 2006 | 01:38 AM
omni's Avatar
omni
ok I'll do that. thanks
