No Backwards-Transmission Problem
Old May 21, 2006 | 05:52 PM
pokerpuller's Avatar
pokerpuller
So I rebuilt my C6 without badshoe's video (which i now regret like crazy) and now it won't go backwards.
When I shift from park to reverse, the motor sounds loaded, but the tires dont go backward.
When I shift from reverse to neutral, the motor goes back to the unloaded idle sound. Once in neutral, the truck will roll forward, but not backward.
Drive seems to act the way it should, as does shifting into 2.
When I shifted into one from two it made a loud ugly noise so I'm afriad to try that again.
Any one have any ideas?
I just swapped out the linkage, hopefully thats where my mistake is.
-kit
Old May 21, 2006 | 10:22 PM
thesprocket26's Avatar
thesprocket26
Pull apart your trans and see what you may have missed. Look for broken pieces.
