Leaking steering box- any suggestions
Old May 21, 2006 | 03:46 PM
1954blueoval's Avatar
1954blueoval
I rebuilt the steering box on my F-100 and I have a little leak from where the thrust bolt comes through the plate on the side. I have tried a small oil drain plug washer and this didn't do anything. Does anyone have any other ideas?
Old May 21, 2006 | 03:47 PM
Tennesseedave's Avatar
Tennesseedave
The Lucas stuff has worked for me like gangbusters...
Old May 21, 2006 | 04:54 PM
1954blueoval
Which Lucas product did you use?
Old May 21, 2006 | 08:26 PM
snipa's Avatar
snipa
mines leeking from the exact same spot on my 53
It completely will drain of 85wt gear oil over the coarse of a year if I don't watch it
I'd like to know how to stop it myself
Is there a bottom plate on the box the remove(it kind of looks like the bottom might be removable)
I just want to know if there are metal shavings in there from being possibly run while the box was dry
I didn't discover the box was dry until after many years of driving
Old May 22, 2006 | 08:09 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Many years ago I had a leak in a steering box in a 34 Plymouth. A friend suggested I start adding STP to it instead of gear oil. I tried it and it leaked less and less over time as I kept filling it with STP. Eventually it stopped leaking and I never had any more problems with it. I suppose it had something to do with the thickness of the STP. I didn't notice any difference in how the steering gear worked.
Vern
Old May 22, 2006 | 05:43 PM
Tennesseedave
The Power Steering stuff, whatever they call it...
Old May 22, 2006 | 07:12 PM
Brian_B's Avatar
Brian_B
Mine is leaking as well. I haven't really looked at where yet. There are other issues currently. The steering is tight and all though.
1954blueoval: If the lucas stuff works for you, please let me know.
