Ignition Help
Old Dec 31, 1969 | 06:00 PM
Guest
Guest
Posts: n/a
Ignition Help
Old Mar 22, 2002 | 05:54 PM
CRJ900's Avatar
CRJ900
Ignition Help
On a 68 f100 360, I put the pertronix coil , and ignitor in. I have 7.5mm autolite wires already. But 2 are 7.0mm wires... would this matter? do i need to get 2 more 7.5mm. Or do i need to get 8mm wires cus of the flamethrower and ignitor. Also What gap would you all suggest me putting my plugs at? Its at the stock .034 now, i think i remember someone saying i should go with .44 but im not sure. Please give me your imput on this. Thanks
Old Mar 22, 2002 | 06:37 PM
Mil1ion's Avatar
Mil1ion
Ignition Help
Go with 8mm wires and it was me that said you can go to .044 not .44 !
Dennis https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=1733&.jpg
[i][font color=red]Calgary,Alberta,Canada[/font][i]
[font color=blue]Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [font/]
78 F-150 429CJ,Silver, Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon
Old Mar 22, 2002 | 08:18 PM
CRJ900's Avatar
CRJ900
Ignition Help
[updated:LAST EDITED ON 22-Mar-02 AT 10:00 PM (EST)]Yea,..... u know thats what i ment. anyway, 7.5 to 8.0 will really make a difference?? because there 30$ and i dont wanna waste my money.
Thanks dennis
Old Mar 22, 2002 | 09:42 PM
Mil1ion's Avatar
Mil1ion
Ignition Help
I know that $30 towards S P wires is more practical than $15-20 on a Flames out the tailpipe.
84 Volvo DL Wagon
Old Mar 22, 2002 | 10:25 PM
CRJ900's Avatar
CRJ900
Ignition Help
hahha yea, but i really wanted those flames
Old Mar 23, 2002 | 08:38 AM
CRJ900's Avatar
CRJ900
Ignition Help
OK so u are saying that 8 mm will really make a difference??? in what ways
Old Mar 23, 2002 | 11:28 AM
Mil1ion's Avatar
Mil1ion
Ignition Help
Less resistance >especially if they are not radio interference wires.
Question to you:
Does electricity travel easier through a 20 gauge wire or an 8 gauge wire ?
Chris ,Didn't you read those articles I sent you?
They were loaded with technical information.
84 Volvo DL Wagon
Old Mar 23, 2002 | 11:31 PM
lshort's Avatar
lshort
Ignition Help
[updated:LAST EDITED ON 24-Mar-02 AT 00:32 AM (EST)]I belive that the 8mm rating on spark plug wires is refering to the thickness of the insulation not the conductor.A 8 mm conductor is equal to a #1 gauge.This is more like a battery cable than a spark
plug wire.
larry
Old Mar 24, 2002 | 12:19 PM
Mil1ion's Avatar
Mil1ion
Ignition Help
Thanks for the explanation.
You're correct, I should have been more specific.
I'm sure the wire part of an 8mm wire is larger thus being more efficient as the performance wires are.
I assumed again that Chris would understand what I was stating.
In regards to, size of wire vs resistance
84 Volvo DL Wagon
Old Mar 24, 2002 | 01:20 PM
kevins70's Avatar
kevins70
Ignition Help
I just put together the accel universal 8mm wires. The wires are fat!! Compared, the 7mm Autozone wires I have are sewing thread. I don't understand why they can't all be at least a descent thickness. For the company to save a few pennies on the wire is rediculous on a $20 product. It's kind of like car stereos with those weak little harness wires.
The wires go for $30 at Pep Boys. I got them on Ebay for '$22.00 to your door'. The guy is great. 'Chimptoast' or something. Btw- ignitor is $59.00 to your door on Ebay too.
Question: I was wondering what the gap differences will do? I see(in operaters manual) that the 390 should be at .032-. Why .044? Will it cause more gas to be used? I measure autolite platinums preset at ~.041. Should I change them?
Old Mar 27, 2002 | 09:32 AM
DavidB's Avatar
DavidB
Ignition Help
Very simplified explanation: You want the wider gap so that you will have a bigger,longer duration spark to better ignite the fuel. You need a higher voltage to get the spark to arc across the wider gap. High output coils produce higher voltage. Larger spark plug wires (larger diameter = lower resistance =less voltage drop across the wire = higher voltage at the wire tip) provide a higher voltage at the plug. In general, providing a higher voltage at the plug and using a wider gap will improve performance. The thicker/better insulation on the plug wires also helps prevent arcing through the insulation to surrounding objects. Get the good wires. Be happy.
Old Mar 27, 2002 | 01:42 PM
Mil1ion's Avatar
Mil1ion
Ignition Help
That's exactly what was on my mind David, I just couldn't put it all together and write it down.
Thank you sir for your addition to the post.
https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=3180&.jpg
http://community.webshots.com/user/mil1ion
[font color=green] Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
84 Volvo DL Wagon [/font]
