Blower Problem...
May 21, 2006 | 01:56 PM
Blower Problem...
Hey guys,
The blower on my '89 F-250 only works when the selector is on the highest speed. Is it the actuall blower motor or is it an electrical problem? What do I do? Thanks.
May 21, 2006 | 09:32 PM
Easy fix, the blower resistor is shot. About 20 bucks at Napa etc..
The resistor plugs into the plastic air duct with 4 or 5 wires attached.
May 22, 2006 | 05:55 AM
Would it be plugged in close to the registers or closer to the blower itself? If its close to the registers, which one? Thanks for the help so far.
May 22, 2006 | 08:43 PM
On my 95 Taurus it's under the dash/passenger side behind the glove box.
On my 87 Ranger, it's under the hood/passenger side near blower motor.
Take a look around, should'nt be hard to find.
May 23, 2006 | 03:57 PM
I found it. How do I test it to see if it's bad?
Thanks.
May 23, 2006 | 04:37 PM
If the plastic looks melted, it's definetly shot.
Autozone can probably test it for you.
Or if you have the wiring diagram, it's very simple to test with an ohm meter.
May 23, 2006 | 08:13 PM
Well, I know that Autozone doesn't sell the resistor, but maybe they do test it. They said it's probly a dealer item.
May 23, 2006 | 10:42 PM
Just replace it. 87XLT is right, 99.9% sure thing.
May 24, 2006 | 01:28 AM
May 24, 2006 | 05:46 AM
O.k guys thanks for the input, I'll go get one tonight.
Dec 10, 2006 | 11:29 PM
i have the same problem for my 1995 ford bronco. Where can i locate this Blower motor resistor?
Dec 26, 2006 | 12:52 PM
Deepbass, did you ever get that resistor problem fixed? and was that right next to the fan box on the pside firewall?
Mar 30, 2007 | 02:35 PM
blower
i have the same problem with my 2002 ranger blower only works on high .wondering where the resister is located
Mar 30, 2007 | 05:52 PM
most all resisters are located on the heater box so that the air can keep the coils cool.
donp390
Jan 12, 2014 05:25 PM
6.9lXLTf250
Sep 8, 2012 11:14 PM
lbonilla
Aug 24, 2011 06:22 PM
69oiler
17
Jun 4, 2005 07:26 PM
1995 ,
2002 ,
87 ,
89 ,
blower ,
bronco ,
fix ,
ford ,
location ,
motor ,
problem ,
ranger ,
resistor ,
truck ,
working
