Key wont open lock.
Old May 20, 2006 | 09:44 PM
MemOrex's Avatar
MemOrex
Key wont open lock.
Hey i got a problem with the Key not unlocking the passenger side. The key does turn, but the lock doesnt move. Any ideas whats wrong there?
Old May 20, 2006 | 10:19 PM
Van Zant's Avatar
Van Zant
one of the rods could be disconnected. does the key keep turning or stop like normal? if it stops like normal try pulling the door panel and look for the rod connecting to the plastic clip on the lock cylinder.
Old May 21, 2006 | 03:04 AM
MemOrex's Avatar
MemOrex
yea, it stops like normal.. I'll pop the panel off and check it out.
Old May 21, 2006 | 11:23 AM
Leader's Avatar
Leader
Try some WD-40 in the lock & just work it back & forth. These locks tend to stick every now & then if not used regularly
Old May 21, 2006 | 01:00 PM
KW160's Avatar
KW160
I had a problem like this a few months ago and the solution was not intuitive. It was on the passanger side. The key would turn but it would not unlock the door. Turns out the outside door handle had rust on the rod that connects the button to the latch mechanism. This cause the button to not pop out all the way when the outside door handle is used. Is the button isn't out all the way the key will not operate the lock. Took me an hour to figure it out.
Once I figured it out I took out the outside door handle and grinded the rust of the button shaft.
