Accelerator assembly question
Old May 20, 2006 | 07:29 PM
trike1946's Avatar
trike1946
Does the accelerator assembly need any adjustment when it is put in? I did it not long ago and just put in the bolts and used it. Today I was told it needed to be adjusted. ??? Is the TPS part of the assembly? On my IDI it needed adjustment, but it is under the hood. Thanks for any help.
Old May 21, 2006 | 01:25 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
It does not "need" to be adjusted. We tweak them out a little bit to make them more sensitive and responsive.
If you test it with a voltmeter and get less than 4.7v output at wide open throttle you're not getting all that's there.
