Trailer Marker-Light trouble
Old May 20, 2006 | 07:28 PM
Highridge's Avatar
Highridge
Hello all,
I've been reading this great site and finally have something to post about. I've got a 2004 Navigator and I pull a 14' landscape trailer w/ electric brakes. Before I had the Navigator I had an Expedition which I also used to pull the trailer.(the lights worked on the expy) My problem is that the fuse for the side-marker lights keeps blowing. I think this is because the Navigator has the photo-electric auto-lights that go on and off when the light outside changes and the trailer lights also do the same. The brake/turn signals lights and brakes work but those are seperate fuses. I replaced the side-marker fuse and I took the trailer on about 4 trips and the fuse blew again? Any ideas would be appreciated.
Thanks!
Old May 20, 2006 | 07:34 PM
FTE Herman's Avatar
FTE Herman
Welcome Highridge! Does the fuse blow each time the light's come on and only when the trailer is connected? If so, I'd try to locate a an ohm meter and try to locate a short on the trailer.
P.S. What's your favorite mower?
Old May 20, 2006 | 08:04 PM
Highridge's Avatar
Highridge
I don't think it's a short on the trailer becuase my buddy pulls it with his Chevy 2500 and they work fine
My favorite mower? That would have to be my power-trac pt1430, if you could call that a mower
