Bronco II Ford Bronco II
B2 computers? EEC
Old May 20, 2006 | 06:18 PM
Spennyman's Avatar
Spennyman
B2 computers? EEC
Hello,
Does anyone know what all computers are interchangeable with my 89
Bronco II 2.9V6 Automatic? The number on mine is E9TF-12A650-K1B. I still can't find out why my B2's check engine light flickers and tries to stall. It has a new coil,fuel pump,fuel filter,plugs,cap,rotor,TPS and holds 35 psi fuel pressure
at idle. But when you rev it up at around 3000rpms it stumbles and the check engine light flickers. Let off the gas and she smoothes right out. The only thing I haven't tried is a computer. There's a couple of E9TF-12A650-GIA's on
eBay but I don't know if they'll work. Any suggestions?
Old May 21, 2006 | 08:19 AM
rebocardo's Avatar
rebocardo
Sounds like a failing TFI module. Or a failing alternator/battery, which is easy enough to test.
Old May 21, 2006 | 11:40 AM
Spennyman's Avatar
Spennyman
I put a new distributor with TFI module already in it too. Thanks
