KOEO code 81 and 82
Old May 19, 2006 | 05:29 PM
bluneon's Avatar
bluneon
KOEO code 81 and 82
what is the air managment 1 and 2 circuit malfunction? would this be a thermactor code? cuz i do not have the air pump anymore.
and would a faulty knock snesor cause the idle to fluxuate back and forth until the motor dies? i allready replaced the TPS sensor and the idle stays steady when it's first started.
but after it's idling for some time the motor starts to fluxuate it's idle until it dies. it also does this while in drive.
the only codes i get for the KOER:
44 thermactor AIR sys System inoperative right side
13 cannot control RPM during self-test Low RPM check
25 Dyn Responce Test Knock sensor not detected
Old May 25, 2006 | 01:09 PM
bluneon's Avatar
bluneon
nevermind. it's an emissions thing.
but would this affect idle fluxuation?
garys 68
1978 - 1996 Big Bronco
Mar 20, 2017 08:12 AM
Redneckfordf2502002
44
Aug 10, 2015 06:54 PM
patrick77598
Oct 30, 2013 06:51 AM
theperson10
Jan 19, 2011 03:53 PM
detmerdj
Sep 1, 2005 07:16 PM
