Upper radiator hose
Old May 19, 2006 | 01:26 PM
dakota joe's Avatar
dakota joe
Upper radiator hose
I've seen posters talk about replacing the upper radiator hose with one that doesn't go inside the serpentine belt. Where can I get this hose?
Old May 19, 2006 | 01:39 PM
westpsd's Avatar
westpsd
Most parts stores should be able to get it for you. It is for a dual alternator 7.3. Mostly used on ambulances.
Old May 19, 2006 | 03:02 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
it's on Rock auto.com, and it's also Napa part number 9066. it's a wonder what searching can do....
Old May 19, 2006 | 04:20 PM
RushN350's Avatar
RushN350
Just go down to any car quest, auto-zone, etc. and tell them you have dual alternators.
Old May 19, 2006 | 04:53 PM
Calli's Avatar
Calli
Mine is a single alternator and does not go through the belt?? Early '99, see signature. Carroll
Old May 19, 2006 | 04:57 PM
PSNut's Avatar
PSNut
I had a tough time finding one here in Cowhampshire. Well worth the install when it's time to change the belt....bing...ban...boom...done in 5minutes.
Nut
Old May 19, 2006 | 10:35 PM
Kajtek1's Avatar
Kajtek1
Mine 99 F450 is not going through the belt neither.
Must be the pickup size?
Old May 19, 2006 | 11:34 PM
Fat Diesel's Avatar
Fat Diesel
My early 99 doesn't go through either. Sometime after that, Ford wanted to save 2 cents per hose and run it through... Wait. They saved 5 cents on the tie wrap to the casting. They saved 7 cents. The stockholders were ecstatic.
Old May 20, 2006 | 12:38 AM
ccg711's Avatar
ccg711
i have 99 f350 srw with a 6/98 build date on door tag. hose goes though belt. never thought about how it would affect belt change till I saw this thread. gonna suck on side of road.
Chad
Old May 20, 2006 | 08:53 AM
aklim's Avatar
aklim
You can get it from Ford too. About the same price either way. Anyways, the benifit is that when you change the serpentine belt, it can be done at a time of YOUR choosing. Rather than when you are on the road and notice that the belt is cracked and need to change it and thus having coolant all over the place.
