harmonic balancer
Old May 19, 2006 | 12:27 PM
pdqtimetrialer's Avatar
pdqtimetrialer
harmonic balancer
Help! I'm trying to remove my harmonic balancer to replace the timing gear.
I have a harmonic balancer puller kit, but none of the bolts thread into the holes on the balancer! What size thread is tapped into the three holes on the balancer?
Old May 19, 2006 | 03:56 PM
pdqtimetrialer
Figured out the holes were clogged with dirt. I ran a 3/8-16 tap through them to get the screws for the puller in.
Old Jun 10, 2006 | 07:28 AM
MBBFord's Avatar
MBBFord
Mine fell off, how do you put the harmonic balancer back on - what mounting hardware is needed (lost all that stuff). Unbelieveable !!!!
Old Jun 10, 2006 | 03:17 PM
stractor's Avatar
stractor
To put it back on you use the stuff that fell off and you don't have--the bolt and a thick (1/4")flat washer are used to pull the damper back into place and hold it there. Don't remember the bolt thread, but should be a grade 8 bolt.
stractor
Old Jun 10, 2006 | 07:12 PM
pdqtimetrialer
The threads on my '95 were 5/8-18.
Old Jun 12, 2006 | 06:47 PM
Lone Wolf #2's Avatar
Lone Wolf #2
Where can I find a performance balancer for the 300?
