1978 - 1996 Big Bronco
1986 bronco need help
Old May 18, 2006 | 07:45 PM
mike ciano's Avatar
mike ciano
need help my bronco has no fuel gauge or temp ! they went out the other day i looked in the back of the dash! can anyone help?????i got 4.9 under hood wire? relay? i know its not sender!
Old May 19, 2006 | 05:48 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old May 19, 2006 | 12:07 PM
SwampBilly's Avatar
SwampBilly
hey mike i had an 86 ford bronco with a brand new sending unit....sumtimes it wouldnt work but i found that if i wiggled the wires that plug into the sending unit it would start giving me a reading...but did your speed and temp go out at the same time? or seperately...we need to establish that first...it could just be a fuse...or you actual temp sensor needs to be replaced...the 4.9 is the Inline 6 correct?
Old May 19, 2006 | 03:30 PM
mike ciano's Avatar
mike ciano
no they both went out the same time! i pulled dash out unpluged it and pluged back in. checked all fuses. started to look for broken wires under hood.found a few and repaired them. does anyone have a wire chart for this ?found relay under dash near ecm dont know what it is for?
Old May 19, 2006 | 06:59 PM
SwampBilly's Avatar
SwampBilly
well u might have had a short have you recently done some wiring? new radio? lights? do you have dual exhaust? some people put in exhaust and dont think about their wiring along their drivers side....heat DOES take a toll on wires...it sounds like a short possibly....
