Edelbrock Performer 600CFM Tuning / Setup
Old May 18, 2006 | 01:12 PM
eknope's Avatar
eknope
Question Edelbrock Performer 600CFM Tuning / Setup
Does anyone have any resources on setting up and tuning (i.e., mixture setting, vac lines setup, etc.) on an Edelbrock performer carb? I recently installed the Edelbrock Performer RPM kit in my '69 F100 302, Cam, Intake, and Edelbrock 1406 600 CFM carb. The engine runs, but as soon as it starts the rpm goes high and it doesnt idle where it should be.
The idle screw is back all the way down and the choke plate is barely open. Does anyone have any ideas what else i could check i.e., mixuture, vac lines, choke setting, etc. ?
Thanks, Eric
Old May 18, 2006 | 09:02 PM
Twinscrew's Avatar
Twinscrew
Sounds like a vacuum leak. Try capping all of the vacuum ports on the carb and the intake. If it still revs at start-up it may be a gasket leak.
Old May 19, 2006 | 12:38 AM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old May 19, 2006 | 11:20 AM
quehele's Avatar
quehele
Check this page and see if it's what you need. >>> http://www.sacinvest.net/ford/ford_docs
Jetting specs are there. If you need more info send me a message and I'll scan what you need and post it.
Hope this helps.
