My transmission (c6) came out of a lincoln. I already rebuilt it and solved all my tailshaft issues, but now I've noticed that the linkage to the shift rod (steering column type) is different than the truck type.
Long story short, i need to take off both the kickdown lever and the piece on the tranny that connects to the shift rod from the column. How do i do it?
-kit
On a 78 the NSS is located on the side of the transmission.
The single shifter arm comes from column dsifferntly than it does on the Lincoln.
The Lincoln may even have a cable linkage as opposed to the rod.
