Timing Curve and Cam Selection?
Originally Posted by Bear 45/70
Are you insane? You can't run an advance curve like that if you are towing, in a car maybe or a truck that never tows but not towing. You will burn holes in pistons and overheat the motor. He says 40% towing and 40% work with the truck. Better off to start with 10 to 12° initial and end up with 32 to 34° in not sooner than 3500 rpm.
I have gotten as good as 12 MPG towing the boat. I just got started lots to modify yet still stock duraspark II ignition box, stock exhaust manifolds. Truck has original 82K on it.
Have to agree with Bear 45/70. 20 deg is way, way, waaaaaayyy to much initial timing. You may be seeing 20 deg with the vac advance hooked up, but static should be 8-10 deg, maybe 12 if you run good gas.
I'm guessing you either have a timing chain that's installed on an offset or a cam with a ton of overlap to bleed off cylinder pressure. Otherwise, that much initial timing is a sure bet for inevitable 'dynamic dissassembly' of your powerplant.
*Edited to add* Just looked at your sig and saw you have an 86 vintage truck. Now the pic becomes clearer. You have the 8 deg retarded timing set. No wonder you can get away with that much initial timing! If you had the straigh-up timing set you would have already grenaded the engine.
Brad
Brad
The SBCs in my boat now run 20 inital total of 34. gets me up to 65 in rough water.
Brad
A boat and a truck towing are a lot closer timing wise than a car. A boat runs higher RPM constantly than either and if timing was going to burn up an engine it would do it in a boat much quicker than either a car or a truck.
Basicly old school gas started burning fast then slowed down requiring less inital advance and more in the distributor.
Todays gas starts out slow then speeds up requiring more inital and less in the distributor.
Both my truck and boat were timed much as you sugest when purchased. The truck got 6 MPG at best towing a 4000 lbs boat. Now does 12 at 14000lbs. I bet you bairly get that empty. Not trying to be offensive here just trying to make a point. I an not any kid either been building engines for 40 some years. Also have spent the last 16 designing heads, blocks, cams, cranks, pistons, rods ,feads, intakes, exhaust manifolds, oil coolers, oiling systerms, turbochargers, ballance shafts, rocker arms, valve trains and more.
Basicly old school gas started burning fast then slowed down requiring less inital advance and more in the distributor. Todays gas starts out slow then speeds up requiring more inital and less in the distributor.
And balance only has one "L", mr engineer.
Try again.
Brad
BBF250:
have you looked at Crane's Street/Strip distributor? It has multiple mechanical and vacuum advance curves. I agree with Brad on the timing thing for towing. I run 12 initial and a total of 34 on all in around 3500 when towing. With the Crane dist though I can change my all in to 3000 for running around when the truck is empty. Anything steeper (advance) and I start getting pinging on pump gas.
The rate of advance is a different issue. I could change my rate of advance and have the same problem with pinging.I have looked at the marine Crane distributors and didnt like there curves. Was there one though that could be modified by a computer. Dont remember now. In my boat I have two Mallorys converted to Petronics electronic although both have YL tags one has a YT advance system the other is a YL. The YL has a set up the YT cant duplicate. Its given me headaches. They are set up with the same amount of advance but I cant duplicate the same advance curve in both. Because of this engine with the YL is a bit stronger than the other. The YL hasa compound curve the YT has a liner curve and cheeper guts.
I worked on recreational boats for a living and was also a paid mechanic on several offshore and tunnel boats plus own my own tunnel and did all my own work and have forgotten more about boat engines than you will ever know and you are wrong. I've built and maintained race motors for others and myself and have several speed records and championships to my name. You have just been lucky to not fry your boat motor is you cruise with it at all. Under pure race conditions where you idle or run WOT an engine will live with what you say. But for a recreational boat, no way will they live with you recommendations. The only marine engine that ever ran 20° initial were the OMC 2.3 Ford motors and they ran 20° in the car motors too. Your claims of designing engines doesn't fly if you use your timing specs as even EFI motors don't go there with computer controlled timing. Oh yeah, and "bairly" is spelled barely. I never heard of a non-degreed designer for engines. Your degree has got to be in EGO as it sure didn't have a spelling requirement.
#28
#29
Originally Posted by Brad Johnson
Bear, I notice he still hasn't backed up his design claim with any verifiable data. Want to just call this thread done and stop wasting our time with him?
Brad
Brad
At least my first inovative design (the drawings for wich sit 2 feet from me) was a major reason Dan Gurney won the Indianapolis 500. Not a boat race were you spend thousands and win no real money.
#30
