Rear Rotor Replace on 2000 4WD Excursion
Old Dec 14, 2012 | 06:47 PM
geo422's Avatar
geo422
got all the rear brakes done.The excursion stop good no pulling or anything at high speeds I hit the brakes hard and everthing was great. then I left it alone for about a week drove it today ,when I hit the brakes hard at 80 mph the excursion did a nose dive but pulled sharp to the left. tryed it several more times at reduce speeds and the same front end went to the left.I did not replace the front brakes.. on the rear everthing is new .any advice is welcome thanks george
Old Dec 14, 2012 | 06:57 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I found frozen caliper slide pins on the front and back of mine. Mine were frozen up on front left and right rear. The boots had not been put back on correctly after someone did the last brake job, and water got in there.
My symptoms were pulling HARD to the left on braking as well.
Old Dec 14, 2012 | 07:04 PM
geo422's Avatar
geo422
I put new caliper side pins in and also new caliper bracket, new caliper ,rotor ,pads .used the correct grease on the pins .. car was parked in garage past week.. I will check the new slide pins and see if they are working .I know the front brakes is old.thanks george
Old Dec 14, 2012 | 10:35 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I am thinking your front caliper slide pins are stuck as well. I was not saying the rears are still bad....for clarification.
Old Dec 14, 2012 | 10:51 PM
EXv10's Avatar
EXv10
It should have pulled to the right.
Old Dec 14, 2012 | 10:54 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Someone else said that a while back, too. But I assure you, it was pulling to the left!
Old Dec 15, 2012 | 05:10 AM
geo422's Avatar
geo422
At 80 mph I had to hit the brakes hard , I can assure everone the excursion nose went down then hard to front left
I know That I am going check the front and replace if I find anything then post it here. Thanks
George
EXbowtieguy
Mar 23, 2025 12:29 PM
OJs DNA
Jan 7, 2022 08:11 AM
MackGuy
Sep 12, 2012 12:45 PM
dfronek
Jan 26, 2011 05:13 PM
TennesseeMustangPerf
Dec 17, 2010 01:18 PM
