Smog problems
Old May 18, 2006 | 12:22 AM
trinogt's Avatar
trinogt
Timing was set according to the valve cover sticker. It corresponded to the calibration code found on a tag attached to ignition coil. You may have to fudge the timing to get it right, but I think 10 degrees BTDC is a good starting point for that engine.
Old May 18, 2006 | 12:34 AM
4doogie's Avatar
4doogie
yea i dont have a valve cover sticker anymore, guess the new motor didnt come with one. so start with 10 and go from there?
Old May 18, 2006 | 12:45 AM
trinogt's Avatar
trinogt
Yeah. If gutless, advance a couple degrees and drive. If you get ping, back off a little. You don't want any ping when you accelerate. Heavy loads may make that advance setting worse.
Advancing is to turn distributor body clockwise, in case you were wondering.
Mark
Old May 18, 2006 | 12:52 AM
4doogie's Avatar
4doogie
thanks, see i think the vacume leak is screwing with me, cause its changing the vacume advance so its changing my mixture. thus screwing me up, i have a sniffer so im getting it all ready b4 i take it to a smog station, its CO levels are the ones im having problems with.
Old May 18, 2006 | 01:05 AM
Mil1ion's Avatar
Mil1ion
Quote:
I think on the 79 400 they came out retarded about 4 degrees.
All the info you require about this is on one of my web pages.
I'm really suprised Mark didn't say anything about that
Calibration code
8-62T-R0
The tune up Specs are in 2 nd section of page.
look at info corresponding to the calibration code.
http://mil1ion.clubfte.com/78Calibra...e-upSpecs.html
EDIT :
Great that line is empty
I'll look it up for you in my NEW emissions book
Old May 18, 2006 | 11:22 AM
trinogt's Avatar
trinogt
I didn't need to: I knew Dennis would be here with links and everything!
My evil plan worked!
lol
Old May 18, 2006 | 12:14 PM
Mil1ion's Avatar
Mil1ion
I have a couple of choices for you now.
Calibration codes
9-17P-R0
9-17Q-R0
|WYG|SS
May 27, 2010 09:03 AM
8525ford
Sep 29, 2009 04:56 PM
93'colttsi
Jun 30, 2008 08:04 PM
f100beatertruck
Nov 15, 2005 07:54 AM
terekpau
Sep 9, 2004 12:07 PM
