Sponsored by: Real Truck
removing headlight
Old May 16, 2006 | 09:56 PM
fordboy2's Avatar
fordboy2
removing headlight
whats the trick to getting the headlight clips off and releasing the bottom fastner that you cant even see, as I am changing my headlights from the 2000 style to the 2002 style. Thanks in advance
Old May 16, 2006 | 11:45 PM
RACERX7775's Avatar
RACERX7775
Are You Trying To Change The Headlight Or The Marker Lights? I Think You Have To Remove The Marker Lights Via The 2 Screws At The Bottom. Then You Should Be Able To See The Clips On The Headlights.
