Sponsored by: Real Truck
Trailer brake hook up
Old May 16, 2006 | 08:52 PM
mikeb2's Avatar
mikeb2
I bought a travel trailer last week and I am going to go get it memorial weekend. I ordered a trailer brake controler to install on my superduty and I was wondering if anyone knows if there is a seperate wiring harness under the dash to plug in to the controller or will I just have to wire it in? My truck is a 99 f-250 powersatroke crew cab with the tow package. I don't get the controler until monday which means I will have to install it after work so I was trying to figure this out ahead. Thanks in advance for your input. Mike b.
Old May 16, 2006 | 09:31 PM
sltrrco's Avatar
sltrrco
Look up under the dash and there will be a gray or brown plug under the dash by the ashtry. you can get the other end from ford a trailer supply place.
Old May 16, 2006 | 10:53 PM
mikeb2's Avatar
mikeb2
Thank you.
Thank you that helps- Mike b.
Old May 17, 2006 | 07:20 AM
FortyFords's Avatar
FortyFords
Depending on your brand brake controller ,some of them have a cable already made to plug in the plug on the truck and in the back of the controller.
Prodigy/tekonish(sp) has them already made up.
Rich
Old May 17, 2006 | 08:53 AM
Texascadillac42's Avatar
Texascadillac42
Yep, that little harness you plug into is fairly well hidden. With the fuse panel door off, you can look up towards the middle of the vehicle. There will be a hole in one of the dash supports, and the harness will be clipped to the back side of that. A few minutes of diggin and you should be able to find it. If not, post back up, and I will find a pic for you.
Old May 17, 2006 | 09:47 AM
planders_99's Avatar
planders_99
Smile Prodigy with wire harness
I bought the prodigy and the premade wire harness. It took me longer to find the plug under the dash than to mount the controller. .
-Pete
Colorado Springs
