Back Fire when Decel
Old Apr 17, 2002 | 10:37 PM
IronSled's Avatar
IronSled
My 1970 f-100 refuses to stop back firring when I decelerate. I hade a 360 until the #5 exhust vale melted on me so replaced the heads with a set off of a 390 i have sittin around waiting to be rebuilt. Along with that I changed the distributor, coil, plugs, wires,fuel pump, timing chain, rebuilt the stock 2-brrl carb. Now I can seem to find a point in the timing spectrum where I dont blow black smoke when the hammers down, and back fires when slowing down.
Any help would be a big help
Old Apr 18, 2002 | 02:00 AM
jonesn's Avatar
jonesn
Maybe the black smoke is because of a rich carb, and the backfires the result of exhaust leaks.
Old Apr 18, 2002 | 05:09 PM
IronSled's Avatar
IronSled
Hey thanks for the info Ill give that a try. I do have leak on the pass side. Do you have any tricks for adjusting the air/fuel ratio?
Old Apr 18, 2002 | 06:17 PM
jonesn's Avatar
jonesn
Once you locate the mixture screw you have to play with it a little. The trick is to adjust it to the point where the engine idles the fastest and then adjust the idle down with the IDLE screw.
Old Apr 18, 2002 | 07:46 PM
IronSled's Avatar
IronSled
Hey thanks alot
Old Apr 19, 2002 | 04:15 AM
jowilker's Avatar
jowilker
