Bronco II Ford Bronco II
Changing A/C Belt
Old May 16, 2006 | 07:53 PM
Aces_&_Eights's Avatar
Aces_&_Eights
Changing A/C Belt
I am looking for a little help changing the A/C belt on my 1988 Bronco II. I have loosened all the nuts and cannot get the compressor to rotate to put the belt on. Is there something I am missing? Thanks
Brandon
Old May 16, 2006 | 08:56 PM
fordxfour87's Avatar
fordxfour87
Try wd-40, unless you forgot a nut or two, ( i had to remove the a/c once, trust me, those bolts are hidden) it should work out.
Im replacing all the belts on my bronco, there just too old. Found out today that the alternaters on its way out (bent shaft, worn bearings, rotor is hitting stator), so i got to find some money for a new one soon.
Old May 17, 2006 | 01:32 PM
fl1a's Avatar
fl1a
I nbelieve there is another bolt at the rear of the point that the compressor
pivots, and all the bolts have to be really loose. good luck.
Rusty_S
Apr 5, 2015 01:43 PM
82inline6
Jul 11, 2012 08:58 PM
skierbri10
Feb 15, 2010 10:13 PM
mtandorfer
Aug 3, 2004 10:41 AM
cadiecast
Aerostar
Aug 27, 2002 12:39 PM
