What next
Old May 16, 2006 | 04:29 PM
Chance_Thomas's Avatar
Chance_Thomas
What next
Ok I read several threads about adding intake, exhaust and Chip or Tunner. I did all 3 what can I do next that doesn't cost a small fortune.
Old May 16, 2006 | 04:48 PM
CAT_man_963's Avatar
CAT_man_963
Gauges to go with that chip/tuner!!!
Old May 16, 2006 | 04:50 PM
jtharvey's Avatar
jtharvey
For sure some gauges should be in order. But, look into the hutch mods, also known as the pre-pump and in-tank mods. They get rid of all the places that air is being sucked into the fuel likes, and there are places where it's happening. Run a search on the topics and you should pull some good info.
Old May 16, 2006 | 06:22 PM
Muktown's Avatar
Muktown
i would put in guages before you even use the tuner a 10k mod is cheap
Old May 16, 2006 | 07:55 PM
Wieckster's Avatar
Wieckster
do you need to do the 10 k mod if you are getting a Jody chip and if you do what does it help with the chip?
Old May 16, 2006 | 08:33 PM
Muktown's Avatar
Muktown
you dont need it and i dont know about jodys chip but with my hypermax chip it works great. a noticable power increase. i have an adjustable one because i can turn it back to stock most of the time but if i need extra power (and black smoke for the ricers) i can turn it up. it fools the computer into thinking oil pressure to the injectors is low so it raises it to make the injectors fire harder= more fuel. i dont see why it wouldnt work with a jody chip but maybe someone has a definate answer for you. it is a from slp diesel performance but i think black cloud has the same one only i think they call it a 18k power module. here is a link or you can do it yourself with a resistor from radio shack but i think some had a rough idle by doing it that way. i recommend it and i did notice about 1-2 mpg increase unless that was due to something else but it diddnt hurt milage and increased power http://www.puredieselpower.com/catalog/product_info.php?cPath=30_32_40&products_id=80
Old Jun 28, 2006 | 05:13 PM
genie144's Avatar
genie144
Do you think this is similar to what the EZ from Edge does? The claims made seem very similar to what I have read about the EZ.
Sam
