power window problem please help!
Old May 15, 2006 | 11:17 PM
arron9's Avatar
arron9
Hi, my x has a window problem all the windows work fine sometimes and then for no reason it wont work at each door. now if i lock all the windows out at the drivers side i can control all of them just fine. but i now notice that when i push the window lock button to allow the other doors to run by using there own button it make the lights dim as if there is a draw. i know there is a draw because it will kick out the power window curciut breaker untill i swith it back to drive controll. i have taken all the other window switches out to see if it is one of them but thats dont seem to be the problem. nay help would be great
arron9
Old May 16, 2006 | 11:28 PM
RACERX7775's Avatar
RACERX7775
Sounds Like A Shorted Window Motor. I Would Unplug 1 At A Time And When You Unplug The Bad One, Everything Should Work Fine..
Old May 17, 2006 | 05:54 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome arron9 to Ford Truck Enthusiasts!
…..See you on the boards.
