Sponsored by: Kumho
need help with solution to non-returning wheel.
Old May 15, 2006 | 09:39 PM
I_Thnk_Ford's Avatar
I_Thnk_Ford
I have a 71' crewcab 2wd that the steering doesn't return back.
It isn't pulling; it just doesn't return either when making a corner or driving 40 mph and turning it slightly. It just keeps going in the direction I turn it.
- I checked the toe-in and it is correct. (3/32)
- The passanger side camber is 1 degree and the drivers side is 2 degree.
(1/2 to 2 1/2) (1 preferred.)
- The passenger side caster is 1/2 degree and the drivers side is 3 degree.
(1/2 to 5 1/2) (3 preferred.)
I have put new kingpins in and they where not too tight after install.
If someone could enlighten me on the theory of caster as to what will more caster do and what will less caster do.
Any thoughts would be appreciated.
Robert P.
Old May 15, 2006 | 11:17 PM
I_Thnk_Ford
Found the problem. I had the definition of positive and negative caster backwards.
Positive caster is the top of the king pin towards the rear. I now have them towards the front. Which turns out OK, because I have done the I-beam flip and had to make brackets to lower the back of the radius arms. Now I hope to just shim them further down.
Bye.
Robert P.
Old May 16, 2006 | 10:51 PM
Tjax's Avatar
Tjax
I have the same issue with my '82 F250 2WD. Is this just an allignment issue?
Old May 16, 2006 | 11:11 PM
I_Thnk_Ford
Yes it is. Might be just a toe problem but could be a caster problem.
As it turns out; I am going to swap the I-beams aaaaggggaaaaiiiinnnn rather than dropping the radius arms alot.
Hopefully have it all put back by this weekend and tighten her up to get her back on the road.
Robert P.
Old May 17, 2006 | 05:31 AM
Torque1st's Avatar
Torque1st
Posting Legend
This problem can also be the result of a bad steering box or one that has been mis-adjusted.
Old May 17, 2006 | 12:26 PM
300-6's Avatar
300-6
How would you tell if it's not adjusted right?
Old May 17, 2006 | 09:10 PM
wickymustang's Avatar
wickymustang
How hard is it to turn your wheel? Also, when you turn left to full lock how many turns is it? Compare this number with how many turns to the right to full lock.
