72 with power steering
Old Apr 19, 2002 | 03:23 AM
whitebenz's Avatar
whitebenz
Post 72 with power steering
Old Apr 22, 2002 | 06:07 AM
whitebenz's Avatar
whitebenz
I have a '72 F 250 explorer heavey duty with power steering. What year power steering boxes are interchangable with it?
Also, how rare is my explorer?
thanks
dj
Old Apr 23, 2002 | 12:39 PM
buzzard's Avatar
buzzard
You should have the standard Ford gear in your truck if it's original equipment. You can get a gear out of 70-79 for sure, maybe others as well.
Old Apr 23, 2002 | 01:53 PM
whitebenz's Avatar
whitebenz
Thank you Buzzard That is what I thought I had heard, but I wasn't sure.
thanks again
dj
Old Apr 23, 2002 | 02:58 PM
72stepside's Avatar
72stepside
I've considered power steering for my 72 F100 but found that it takes a special gearbox. 1973 and up have adjustable steering columns. The 72 takes a gearbox that is shorter in the direction where the column bolts on. Bendix made one that works. Otherwise, you have to get a power steering column which is shorter. I saw those at the Supernats last spring. There was a pretty good price tag on them. I wonder if you could take the whole set up from a 73+ and try it????
Chris
Old Apr 23, 2002 | 07:34 PM
DAV1972's Avatar
DAV1972
[updated:LAST EDITED ON 23-Apr-02 AT 08:38 PM (EST)]In '72 power steering was an option. The main difference is the steering shaft. You would need to get one from a truck that originally came with p/s. You could change out the whole column but all you really need is the shaft because of the length. I changed mine about 15 years ago and I seem to remember that it was a direct bolt on. There was also a problem with the plate that holds the end of the column inside the engine compartment. I really don't remember what that was but I had to use the one made for p/s. I JUST RE-READ ORIGINAL POST AND REALIZED IT WAS CONCERNING AN F250!! DISREGARD THIS POST. SORRY!
Old Apr 24, 2002 | 12:53 AM
whitebenz's Avatar
whitebenz
Thank you for all of the help, You also made me realize that I forgot to mention that I am replacing the worn out factory box with a used one (if I can find a good one) So I already have the colum. Thank you for your help.
dj
