grunt starting
Old May 15, 2006 | 01:16 PM
hdman6's Avatar
hdman6
Question grunt starting
Hi all, I have a question. I have a ford F-350 PSD 7.3 crewcab lariat. for the last 2 weeks i have noticed that when i start the truck for thew first time say after a long setting the truck grunts to turn the motor over at first. Sorta like a dead battery. It does start though. After i run it say to work it will start fine. Do you think maybe the batteries are not holding charge anymore? or one maybe isnt? They are the original batteries (2002) in the truck. maybe some ideas on this. Thanks Jeff
Old May 15, 2006 | 01:22 PM
dagren99's Avatar
dagren99
Batteries
My guess is @ 4yrs old - it's one or both batteries. I'd replace the pair.
DG
Old May 15, 2006 | 01:24 PM
hdman6's Avatar
hdman6
yep thats my plan i think the charging system is ok or else they would have died already
Old May 15, 2006 | 02:09 PM
clintbonnie's Avatar
clintbonnie
My stock batteries on my 99 are still going strong after 7 years.. Do you have a site glass on top of the battery? It should show green in color if the battery is OK.. Or just pull them and have them check'd..
Old May 15, 2006 | 02:25 PM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
Wow, 7 years on batteries. I'm impressed. You must start it about once a month. 4 years is about it for the life span of batteries especially if you are doing much cold weather driving. Wow 7 years, I wouldn't hold my breath.
Old May 15, 2006 | 04:19 PM
Medic 66's Avatar
Medic 66
Yeah I had original 99 batteries too....they were still going great at the beginning of 2006....but it was just a matter of time before i got stuck somewhere due to one dying, so i just went ahead and replaced BOTH.....
Old May 15, 2006 | 05:15 PM
hdman6's Avatar
hdman6
Cool
i checked my batteries, one is red the other is green. Will the truck still start with one gone bad. I put the charger on the red one hoping it will charge it up a little. I plan on changeing them both on friday. Hope it hold out until then. thanks for all you guys help out there. Jeff
